Signs of bad ball joint? - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 05-25-2005, 11:42 PM
Default Signs of bad ball joint?
what are the signs for a bad ball joint?
im getting a loud creeking noise at times around the front right of the car..almost like its rubbing sound at times....its real bad at low speed...i pulled the tire...didnt find anything obvious....
Old 05-25-2005, 11:55 PM
BFlan2001's Avatar
Default RE: Signs of bad ball joint?
is it a squeaking noise or a click? is it only when the wheel is turned or does it happen going straight too?
Old 05-26-2005, 12:02 AM
it happens going straight as well...and its a squeaking noise...i can stand above the right front..and push it down rapidly and it squeaks real bad...
i inspected the bushings..they all seemed in pretty decent shape...
Old 05-26-2005, 12:07 AM
BFlan2001's Avatar
that sounds like your control arms
Old 05-26-2005, 12:11 AM
control arms...not a spring?
i checked the bushings..they look in decent shape....i'll have to do a test...spray some WD40 on each bushing one by one..and see if goes away....
what are some signs of a bad ball joint? thats my worst fear at this point..heh..
Old 05-26-2005, 12:21 AM
BFlan2001's Avatar
ball joints will make more of a clunking sound..pull into a few driveways at a moderate speed, and listen for a clunking noise...
Old 05-26-2005, 01:01 AM
thats how i first noticed it..pulling into my driveway...is it a dull clunk? mines more of a squeaking at moderate speed....
Old 05-26-2005, 01:09 AM
BFlan2001's Avatar
it's more commonly a fairly low-pitched clunking noise...if it's your tie rod ends you'll also feel the steering wheel loosen up pulling into driveways, it will jitter slightly, in synch with the noises you hear...almost every time i hear about a squeaking problem it turns out being a control arm issue.
Old 05-26-2005, 02:17 AM
Squeezing or scrunching sound like two balloons being rubbed is shrunken control arm bushings, not a safety issue, but annoying.
A clunk when going over a bump, pothole or a speedbump is ball joint.
Old 05-26-2005, 04:16 AM
Im actually getting both of these noises, which is making me quite scared. im getting a high pitched squeaking noise when i go around turns, and im getting the clunking noise when i go over small bumps or driveways. have any ideas? ball joints and control arms?
Dustin
Reply
Thread Thread Starter Forum Replies Last Post
Tie rod or ball joint? Help please!! AudiTurbo B5 Models 7 03-21-2012 02:47 PM
Tie rod, ball bearing, and ball joint ShqeviTT00 Audi TT 2 09-15-2010 01:41 PM
ball joint blazinhaze609 Audi A6 1 03-05-2009 02:50 PM
ball joint mattr7786 S Car Model Line 1 08-18-2007 06:14 PM
Ball Joint morrisonjd84 Audi A4 2 12-14-2004 02:43 AM
Tags
a4, arm, audi, bad, ball, clunk, control, front, joint, joints, loud, noise, signs, sound, squeaking, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
