Signs of bad ball joint?
RE: Signs of bad ball joint?
thanks for the responses....appears to be my lower control arms...nearest the engine...sprayed with a lil WD40..and the squeak went away....not a big deal at all...will replace this weekend...
sorry to bring this up from the dead, but i have a problem with the clunk and need my UPPER front L&R ball joints fixed so i can get an alignment.
is this covered under the service action or just the lowers?
wheres a cheap place for picking up these oem parts?
#19
I just had my front right ball joint replaced this past weekend...i noticed a pretty annoying sounds, like something was dry or rubbing when turning the wheel at slow speeds...i also took off the wheel and found nothing wrong...i originally thought it eas either bad bushings or the control arm, then went and got it checked out and sure enough...ball joint...id say im about 95% positive thats what the problem is...same thing happened to me
