Squeaking noise....
RE: Squeaking noise....
may be your tires touching the shock body due to lowering.. or even the tires touching your guards.
Otheriwise it could be the springs touching if thier are progressive.. though thats more a clapping sound
find the squeaking first then wory about fixin it. take a can of WD-40 and spray one thing at a time then drive it in the manner nessisary to reproduece the sound. It the sound stops. chanses are you've sprayed the right thing. then you know what to fix.
Jack your car up and place jackstands under. Get a 2x4 and lift and lower your rear wheel... you should be able to identify what is squeaking. Thats what I did. It definately could be your control arms... thats what I'd bet on.
