03-06-2007, 12:56 AM
squeaky bird chirp sound
I have a squeaky bird chirp sound coming from the right side of the engine. It normally makes this sound when I'm cruising at 2200- 2700 rpm. I can make the sound fluctuate with the throttle. It also makes the sound when I let off the throttle and its fully closed. My boost also doesn't seem there or if it is, its not great. Is this the normal sound of a bad DV . Ive been searching for an hour and only see a fluttering sound it makes of a bad DV. ASAP I will install a boost Gage to help myself out. But I really wanted to know if a bad DV makes this sound. I cannot replicate the sound in park reving the engine from the throttle while I'm listening close in that area. Thanks.
__________________
98 A4 1.8T
bilstein
H&R
03-06-2007, 01:00 AM
RE: squeaky bird chirp sound
Is it your engine or your wheel? Could it be the wheel bearing going out since it can only be heard when moving???
Josh
03-06-2007, 01:04 AM
definitely not wheel bearing noise, I can make the sound fluctuate with just a little throttle, going the same speed. Ireplaced wheel bearings. Its a different sound. If I floor it there is no sound.
__________________
98 A4 1.8T
bilstein
H&R
03-06-2007, 01:20 AM
Try spraying silicone lubricant on the drive belts and test drive it. Belts often times sound like birds. If you turn on your AC will it change?
03-06-2007, 01:33 AM
all the drive belts are new with fresh timing belt job 5k ago. the sound it there with a/c/ or not. with heat on or off. could it possibly be a vacuum or boost leak. Or a squeaky DV
__________________
98 A4 1.8T
bilstein
H&R
03-06-2007, 01:53 AM
I get a squeaky bird chirp sound only at idle. The fequencydoes not change but the rate/speedincreases to the point that it is almost a solid squeek then it will stop. It starts slow and increases over about a one minute duration then it stops. It sounds like it could be coming from the driver side rear. I just ignore it, it does not seem to be a big "red flag"...I just can't explain it when someone else asks what it is. I just say the hamster wheel neede grease.
If anyone has a fix or an idea I'll look into it.
__________________
1999.5::1.8TQMS::K-04::Volcano Black Pearl::B6 Sport wheels::GIAC::Race N75::Forge DV:
03-06-2007, 02:02 AM
I'll see what my mechanic friend says about it when he replaces my tie-rods.
__________________
98 A4 1.8T
bilstein
H&R
03-06-2007, 02:13 AM
nextel bleep?
__________________
03-06-2007, 02:17 AM
I just replaced tie rod ends this past weekend. They never squeaked, just knocked while going over bumps and made the steering sloppy. It was a quick easy DIY job. No allignment needed after.
__________________
03-06-2007, 02:30 AM
Quote:
ORIGINAL: bluesnapper
I know the tie rods arnt squeaking but I will have him check the bird calls out. For $25 install its worth not getting my hands dirty plus he is doing the alignment because he recently installed my shocks and springs
__________________
98 A4 1.8T
bilstein
H&R
Tags
a4, area, audi, belt, bird, brakes, chirp, chirping, idle, makes, noise, part, sound, squeaky, timing, tt  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
