AudiForums.com
Go Back   AudiForums.com > Audi Models > Audi A4
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Sponsored by Audi Online Parts
Reply
LinkBack Thread Tools Search this Thread
Old 07-31-2007, 10:42 AM
Default Stuck Wheel Bolt, Really Stuck
Hello,
I was trying to take off a wheel bolt on my B6 A4 but this bolt would not budge. I used a carbon steel socket (harder than the bolt) and after tapping the socket in and using a lot of leverage, the bolt stripped.
Two garages have tried to hammer smaller sockets into the bolt to take it off but it simply won't budge.
Today a shop is going to drill off the head of the bolt, heat it and try to unscrew it.
If that doesn't work, they recommended that I get a new set of discs.
Do you guys have any alternatives? The other 4 bolts on the tire come off fine.
Thanks
Old 07-31-2007, 10:55 AM
hiwords's Avatar
Points: 6,893, Level: 54
Points: 6,893, Level: 54 Points: 6,893, Level: 54 Points: 6,893, Level: 54
Level up: 72%, 57 Points needed
Level up: 72% Level up: 72% Level up: 72%
Daily Activity: 20.4%
Daily Activity: 20.4% Daily Activity: 20.4% Daily Activity: 20.4%
Send a message via AIM to hiwords
Default RE: Stuck Wheel Bolt, Really Stuck
try getting a rly long pipe and slide it on the lug nut remover and then turn. that's how mine came off the first time
__________________
Project Albino Donkey
Old 07-31-2007, 11:41 AM
Bolts stripped already and the stripped bolt kits all failed.
The bolt didn't strip because of an impropper fitting, it stripped because too much pressure was applied. An impact was also used but that didn't do anything.
Old 07-31-2007, 12:00 PM
just leave it to the pros and hope they can fix it. man thats some really bad luck that sucks bro.
__________________
EliteTuning1
01 1.8T FWD
GIAC-x chip
Forge 007 dv
Tein S-Tech
Fmic
Techtonics Tuning Borla
bbs lm reps rockin falkenz
wtffwdftw!
Old 07-31-2007, 12:42 PM
TheJazz7's Avatar
Points: 7,292, Level: 56
Points: 7,292, Level: 56 Points: 7,292, Level: 56 Points: 7,292, Level: 56
Level up: 72%, 58 Points needed
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Who the hell put that bolt in? Is it cross-threaded, or is it just waaaaaay over-torqued?
Most shops won't torque to spec (90 ft-lbs) they'll just zap them back on with an impact wrench. Who was the last place to put that wheel on? I'd raise hell with them.
And no, i don't have any suggestions for what to do. Sucks dude, it really does.
__________________
RIP 2001 A4 2.8L - The Day My Audi Died
Old 07-31-2007, 02:12 PM
You could try this tool http://www.sears.com/sr/javasr/produ...&ihtoken=1
__________________
Chris
"I'm a great driver! I drive just like You!"
Old 07-31-2007, 02:26 PM
Points: 6,891, Level: 54
Points: 6,891, Level: 54 Points: 6,891, Level: 54 Points: 6,891, Level: 54
Level up: 71%, 59 Points needed
Level up: 71% Level up: 71% Level up: 71%
Daily Activity: 5.0%
Daily Activity: 5.0% Daily Activity: 5.0% Daily Activity: 5.0%
Get a set of metrinch sockets - they're worth the money...
__________________
2011 Mini Cooper (19k) - stock
2001 Ford Explorer (152k) - almost sold
Looking for a nice avant!
Old 07-31-2007, 02:37 PM
What are they talking about! If there is no chance in hell they can get that last bolt off, all you would need to do is buy a new hub since obviously one hole is plugged. What are they talking about a new set of discs???!!!!
[/align]
__________________
Old 07-31-2007, 02:45 PM
Heat it up and use the tool I linked about.If that dont work then cut it off and replace the lugthat had gotten damaged. The dealer will probably be the only place to get itand it may cost up to $10.
__________________
Chris
Old 08-03-2007, 11:01 PM
The car is fixed now, cost $60. The ship drilled out the bolt with a diamond tipped bit and then heated. Came out after that.
Next project, installing HID's
Reply
Tags
a4, a6, audi, bolt, bolts, car, fixing, focus, ford, hole, lug, nut, stripped, stuck, tool, tt, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
