Stuck Wheel Bolt, Really Stuck
RE: Stuck Wheel Bolt, Really Stuck
ok same thing happend to me, this is what you do, first drill into the bolt, 1/4 in bit or bigger, then find a stronger bolt with a large head on it. then put that bolt on the laithe and get it down to size to fit into the hole you drilled out,then weld it to the stripped bolt using mig or tig.
Mine was stuck and i took it to a tire place and they put an air ratchet on it!!??!WTF![:@] they were retarded because it just turned it into a mangled mess. So there waas no way to get it off with a socket
My welding teacher helped me out since hes got all the goods
hopefully you know where to use a welder and laithe
good luck
[IMG]local://upfiles/22590/7F7937C96BF94A59BADE5EC6890A46A2.jpg[/IMG]
good luck
Trigger200
B7 Models
04-27-2015 11:58 PM
soundquest
01-13-2013 05:35 PM
oceanisbleu
07-30-2009 07:38 AM
