Sponsored by:
Sponsored by:
Water pump replacement?
Old 06-21-2006, 12:25 AM
siders83's Avatar
Default Water pump replacement?
I have a '00 A4 1.8T. My water pump was replaced under warranty at 26k miles. I am now at 75k and ready to do the timing belt. I know it is pretty much routine to replace the water pump when you do the timing belt. Will it save me time and money in the future to replace the water pump again when I do the timing belt or will the pump be good for a while?
Old 06-21-2006, 02:28 AM
acetrebo's Avatar
Default RE: Water pump replacement?
I am not as familiar with your year, on mine (97) changing the timing belt exposes the water pump making it easy to change it. So most people do it while they are there already as preventive maintenence.
Get a Haynes or Bentley manual for your model, and look at the procedure. If you can get to the water pump without removing the timing belt, dont worry about it.
Old 06-21-2006, 03:10 AM
wood_e's Avatar
Bentleys are the best. You can find DIYs on the internet. I think audiworld has a timing belt/water pump guide.
Old 06-21-2006, 06:30 AM
toyolla86's Avatar
dont you have to take off the whole front end. i dont remember but im going to be doing my timing belt too soon.
Old 06-21-2006, 06:34 AM
miked's Avatar
ORIGINAL: toyolla86
Yes.
Old 06-21-2006, 06:52 AM
toyolla86's Avatar
gosh what a hassle. ive never heard of this on any other cars.
has anyone done it yet and how much of a project is this.
a weekend thing or afternoon thing
Old 06-21-2006, 05:24 PM
siders83's Avatar
I would have to take the timing belt off to replace the water pump. That is why I am wondering if I should replace the water pump again even though it was replaced at 26K miles. I guess a better question is how many miles should a water pump be good for? This one has about 50K.
Old 06-21-2006, 05:37 PM
acetrebo's Avatar
If that is the case, replace it.
A lot of t-belt kits come with the water pump. Just do it while your in there so you wont have to go back in later if it were to fail.
It wont cost you much more money or time to do it.
You can see your first one went out at 26k, so I guess you could be at risk if you dont replace it.
Old 03-16-2007, 11:41 PM
yohan's Avatar
so could someone maybe give me a list of the things i'll need to buy for a t-belt/ water pump change
Old 03-16-2007, 11:44 PM
tractioncontrol's Avatar
http://www.ecstuning.com/
The ultimate timing belt kit.
Quick Reply: Water pump replacement?
