Sponsored by:
Sponsored by:
DV performance
Old 03-28-2007, 01:33 AM
98a4T's Avatar
Default DV performance
alright sorry everyone for the BOV thread ill stick with the 007 DV but can you tell a difference in performance when you install your DV or just it just hld boost better and benefit basicallu
Old 03-28-2007, 01:38 AM
Lazer Viking's Avatar
Default RE: DV performance
there is no performance gain.. just holds boost better
Old 03-28-2007, 01:53 AM
Amze's Avatar
Mark it a f*cking ZERO!!
Old 03-28-2007, 03:16 AM
daesharacor's Avatar
From what I've heard, if you have a freer flowing intake and a Forge 007 or comprable DV, it sounds slightly louder.
Old 03-28-2007, 03:24 AM
Flip's Avatar
I didn't notice a difference between my stock diverter valve and my Forge oo7 but it holds boost better.
Old 03-28-2007, 04:53 AM
Jeff's Avatar
Zombie Defense Force
it just wont leak. your car will only be faster if the one you have now is leaking and not holding boost
Old 03-28-2007, 01:48 PM
patty AT forge's Avatar
ORIGINAL: daesharacor
It goes beyond slightly louder, most people will think that you have a vent to atmosphere valve.
As for a difference in performance, if the diaphragm in your stock valve has failed you will notice a difference in spool and potentially peak power. Even if the stock valve hasn't failed replacing it with a valve with a higher spring rate may net you some improvement in either or both of the ways that I've just mentioned, especially in situations when you are transitioning between low and high load conditions.
And when you guys say that there was no difference between stock and the Forge but the Forge holds boost better, what exactly do you mean by that?
Old 03-28-2007, 05:26 PM
xerexb's Avatar
How do you know if your stock DV is bad and not holding boost?
Old 03-28-2007, 05:32 PM
Flip's Avatar
It should feel like your car is a lot slower than it was but to confirm it's your diverter valve you should hook up a boost gauge and see if it drops off when your on the gas.
Old 03-29-2007, 12:10 AM
SouRce4's Avatar
dv = 150 hp increase.
just kidding anyway... yeah they are a nice item to buy in especially if you are getting ur ecu chipped
Quick Reply: DV performance
