Wheel Spacers?!?!
Wheel Spacers?!?!
Does anyone know the maximum size wheel spacers that would be ok for a B5 A4 on 225 wide rubber? Current offset is +45mm, and i've heard that the minimum offset you can go is +35mm, so a 10mm spacer. How about a 15mm or even 20mm spacer?
I'm going after a H&R set with the longer lugnuts, an other cheaper brands?
RE: Wheel Spacers?!?!
Whats wheel baring?
I know i might get some extra wear on the inner of the tires.. but not so sure if theres anything else to worry about?
Are spacers illegal in USA? Cos they are in Australia.. potential danger?
What about a 5mm to 15mm spacer? would that also cause undue stress on the bearings?
ORIGINAL: Jestnomen
Yeah wheel spacers cause undue stress. I wouln't get too crazy with large spacers.
Wow everytime I have a question someone ask it the same day :P
So I this morning I went to get a tire change since I had a bubble in the side of the tire. After raising the car I saw that both read tires had half grip and HALF SLICK !!! The metal ring was comming out .....
So I search on the reason and it seams that my drop is causing it, now that I have read this thread I<m sorta confused, I though spacers were essential when you drop your car.
I'm currently driving on Pirelli P6 P 235/45 R 17.
Any feedback would be greatly appreciated.
