where is the under hood fuse box???
where did thery hide the under the hoold fuse box, my secondary airpump has a mind of its own and i need to shut the dam thing off it wont stop running even when the car is off.. 2000 a4 1.8t
RE: where is the under hood fuse box???
i think there was.. i was told the fuse for the air pump was under the hood.. i know my 99 had a fuse box under the hood but i dont know were it is on the 2000 and i dont feel like riping the car apart to find it
my 2001 doesnt have one... my fuse box is behind that plastic between that you see when you open the door kinda behind the dash, i looked forever and could never find one under the hood so i concluded that there isnt one, lol
blah i know where it is now.. i think i found it on audiworld, the fuse and the relay for the air pump are in the ECU box.. saw the pic from a 01 they said the 2000 is the same.. and i dont have any tools
ORIGINAL: JohnnyBravoA4
Could it be a bad relay? why would the dam thing still turn on when the car is off...
i dont care.. i can clear it every few days with the cruise control switch with the APR ecu.. im going to jack the car up in the am and take apart the pump found a diagram on audiworld that shows you how to rebuild the pump.. also going to replace the fuse and the relay.. how do you check a relay..
