Sponsored by:
Sponsored by:
Which wire to tap into for antenna? (aftermarket h/u)
Old 11-20-2007, 05:56 PM
pyropenguin's Avatar
Default Which wire to tap into for antenna? (aftermarket h/u)
I'm finally getting around to hooking up the correct antenna adapter for my head unit, but I'm stuck. I need a 12v power supply to splice the adapter to, which wire can I tap into?
Thanks
Old 11-20-2007, 08:15 PM
hollisterrobsta's Avatar
Default RE: Which wire to tap into for antenna? (aftermarket h/u)
Use the remote wire from the aftermarket H/U. I believe you need a 5v not a 12v wire, which makes the remote wire perfect. If you require 12v you could always splice into the H/U's power wire, or you could run a wire to the fuse box and attach it to something like "ACC" or a Cigerette Lighter Fuse, those will both be 12v.
skeedy
07-14-2009 08:28 AM
pete7
10-13-2008 03:29 PM
converted
10-20-2007 04:38 AM
SnowSurfns
06-06-2007 10:58 PM
kryptor
11-10-2005 08:21 PM
Quick Reply: Which wire to tap into for antenna? (aftermarket h/u)
