Door locks issue
Door locks issue
I click unlock on the remote and now it won't unlock the doors but I hear the sound from the passenger side at the trunk like it's working. It had been just the passenger side but now the drivers side does it. I have to use the key to unlock the door. I have to open the passenger side from inside but then the outside handle works till I lock the doors again. I also have 2 of the driving lights LED's out. How hard are those to replace?
Hi Kerry G
The lock run on an air system and you have a leak. The sound you hear is the pump and that's a good thing. it means it is working. The challenge is finding the air leak. I have a 2000 S4 with the exact same problem and I am looking to get it fixed as well. From what I have been told smoke needs to be run through the air lines and it will then present the spot that is leaking.
I don't think I want the dealer to do it. No doubt they will book a lot of hours and charge a lot to do it. I am on the hunt for a shop that can handle the job. Right now I am having a smog issue so I got to get past that first.
