Audi A5 This sleek mid-sized A5 coupe offers performance with a roomy interior.
: ECS Tuning :: NEW!! ECS Luft-Technik Intercooler System | Audi B8 A5 2.0T
Old 02-27-2017, 12:25 PM
ECS Tuning's Avatar
Sponsor
Default : ECS Tuning :: NEW!! ECS Luft-Technik Intercooler System | Audi B8 A5 2.0T
The ECS Luft-Technik Intercooler and Charge Pipe System was designed and engineered in-house to provide you with a direct bolt-on system to increase air flow, decrease restrictions, intake temps, and most importantly increase power!
ECS Tuning's Luft-Technik Intercooler features a 21x9x3 aluminum bar and plate core with cast aluminum end tanks which uses factory mounting locations, so that no trimming or cutting is necessary. This makes installation completely reversible, creating a system to optimize performance and provide the clean look that Audi owners have come to expect.
Key Features:
  • Reduced intake temperatures and air turbulence. (Up to 40% improved intercooler efficiency reduced intake temps by as much as
    65*F during solid state WOT loading.)
  • 52% reduced pressure drop
  • Increased air flow capacity
  • Gains of up to 13 WHP and 10 Ft-Lbs WTQ over APR Stage 1
  • Cast aluminum intercooler end tanks
  • Bar and plate design intercooler core
  • 2.50" diameter intake tract
  • 4-ply silicone straight/hump couplers
  • Aluminum tubing powder coated in a tough wrinkle black finish
  • OEM like bracket secures the throttle pipe in place
  • CNC machined MAP flange welded to factory position
  • Eliminates the factory noise pipe
  • Includes all stainless steel t-bolt clamps
  • Easy and direct replacement upgraded system
Gains of up to 13 WHP and 10 Ft-Lbs!
Click HERE to order or for more information
Fits:
Audi B8 A4 2.0T 2009-2016
Audi B8 A5 2.0T 2008-2016
Audi B8 Allroad 2.0T 2013-2016
Be sure to check out our ----> Installation PDF <-----
Let me know if you have any questions.
Jason
Old 03-27-2018, 12:57 PM
ECS Tuning's Avatar
Sponsor
Quick Reply: : ECS Tuning :: NEW!! ECS Luft-Technik Intercooler System | Audi B8 A5 2.0T
