00 A6 4.2 Transmission Gasket Replacement
Hi All,
I have a 2000 A6 4.2 which has oil leak coming from the transmission oil pan. Has anyone removed the oil pan to replace the gasket / sealant? Please let me know if this task can be a DIY and are there any threads available.
Cheers,
williak1
Cheers,
williak1
If it truly is the trans pan, changing the gasket is no big deal. Refilling the fluid is though. It goes in through the bottomof the pan and the level is checked at a specific temperature (30-35*C) using the stand tube in the pan. It's best left to a pro to be honest and be sure you use the CORRECT fluid!
robert.jones
12-10-2008 08:01 AM
robert.jones
12-10-2008 07:56 AM
