Sponsored by:
Sponsored by:
vag-com diagnose on engine and seat
Old 05-04-2007, 03:13 PM
wings7351's Avatar
Default vag-com diagnose on engine and seat
Just got VAG-COM. Want to check two things:
1. Engine: it seems hard to start if let it sit for sometime
2. Seat: my seat memory function just does not work
Can anyone tell me what should I look for in VAG-COM for these two issues? Thanks for the help in advance.
Old 05-05-2007, 01:22 PM
mpw2.7T's Avatar
Default RE: vag-com diagnose on engine and seat
First thing to do is an Auto Scan. You'll probably have lots of codes, but you really want to see which ones are active. Save the scan results. Go into each module that was showing fault codes and clear them. After you drive the car a couple days, go back and run an Auto Scan again. Any codes you see then will be the active codes you need to deal with. Post the codes and maybe someone will be able to help.
NTBugtraq
11-14-2012 04:53 PM
wrnicolet
09-29-2012 08:58 PM
wrighturbo
02-13-2011 03:09 PM
a2thy
02-04-2009 05:42 PM
kdobey
10-06-2008 04:36 PM
Quick Reply: vag-com diagnose on engine and seat
