Sponsored by:
Sponsored by:
'01 Avant top of door not sealing
Old 04-10-2013, 02:12 PM
BoyRacer0013's Avatar
Default '01 Avant top of door not sealing
I have heard about the doors sagging on the sedan. However my door doesn't seem to be sagging, it opens and closes fine but the top of the door dose not close all the way and it creates quite a bit of wind noise. All the weather stripping seems to be fine. I think the window frame may be bent outward?
Old 04-12-2013, 06:57 PM
Looked at it some more today the top of the door (window frame) is definitely bent outward, any ideas how this would happen or how I should go about fixing it?
Old 04-12-2013, 09:57 PM
retho78's Avatar
I would try adjusting the frame, probably just need a little height adjustment. I did that on my A6 sedan and the wind noise has cut down.
Old 04-14-2013, 06:42 PM
yep, here is a picture of the gap, I'm going to adjust the window assembly tomorrow hopefully.
Old 04-15-2013, 05:40 PM
Had to put a couple of washers on the rear lower bolt inside the door and it lines up perfectly now. I was amazed at how easily the door panel came off.
Old 04-15-2013, 08:45 PM
retho78's Avatar
Yep, it's pretty easy ....glad you got it fixed.
louie9011
12-06-2012 08:04 AM
fusion28
03-02-2012 04:41 AM
A4 2000
10-20-2009 11:36 PM
Disturbo
09-27-2009 09:42 PM
lightningrc
06-02-2006 04:33 PM
Quick Reply: '01 Avant top of door not sealing
