17090,17887,18032,16815 for 02 audi a6
Hi All,
I have got the following messages from audi a6, 17887, 18032,16815, 17090. the car runs smoothly and well. can anyone tell me if I can reset the message and drive the car for few more months? will there be any major issues? what will be to cost to fix it?
Please respond at the earliest.
Thanks.
Thanks.
18032:
16815:
17887/ p1479/005241 - brake boost vacuum system: Mechanical failure
possible causes:
Hoses from/to brake boost vacuum pump faulty
possible solutions:
Check hoses from/to brake boost vacuum pump
check brake boost vacuum pump
perform output test
perform short trip
possible causes:
possible solutions:
perform output test
perform short trip
18032/p1624/005668 - mil request signal active (check tcm for errors too!)
possible symptoms :
Malfunction indicator light (mil) active
possible causes :
Fault codes stored in transmission control module
possible solutions :
Check transmission control module for fault codes
possible symptoms :
possible causes :
16815/p0431/001073 - warm up catalyst; bank 2: Efficiency below threshold
possible causes:
Warm up catalyst bank 2 faulty
Check warm up catalyst bank 2
set readiness
replace warm up catalyst bank 2
possible causes:
set readiness
