Sponsored by:
Sponsored by:
1997 2.8L A6 Overheating??
Old 05-26-2005, 06:13 PM
roesroes's Avatar
Default 1997 2.8L A6 Overheating??
I have a 97' A6 2.8L 12v that after about 20 minutes of driving, the AC shuts down, the coolant temp will spike when I idle or slow down. At fist fan point on the guage the coolant warning light comes on and stays on even when guage goes back to normal range. I can tun on the heat and get it to shut off and keep the temp guage from spiking but need to fix ASAP. Car has 110k on it and I replaced the thermostat, water pump, and heater core at 48k (idot I bought car from ran standard anti-freeze) Could this be that the radiator is clogging or should I go Thermostat, Waterpump, radiotor suggestions welcome.
Old 11-30-2007, 05:26 PM
Default RE: 1997 2.8L A6 Overheating??
same here
did you happen to find a solution
Old 11-30-2007, 09:36 PM
NH_USA's Avatar
Is the electric fan running when it gets hot?
Old 12-01-2007, 03:52 AM
FALCOR's Avatar
MINE DID THAT ONCE IN TRAFFIC WHEN IT WAS ABOUT 38 DEGREES C, IT WENT TILL UNDER 3 QUATER ,HAD TO PUT OFF THE AC TO HELP IT COOL. ???
ruthiek
07-09-2013 11:39 AM
tadeo47
09-05-2010 12:27 PM
No1londonboy
03-16-2008 03:01 PM
No1londonboy
03-08-2008 02:05 PM
tarioa4
02-14-2006 07:02 PM
Quick Reply: 1997 2.8L A6 Overheating??
