2.8 thermostat change - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 05-19-2010, 10:15 PM
Default 2.8 thermostat change
Anybody can give me step by step instructions for a 99 audi quattro a6 2.8 thermostat change? And any special tools that may be required?
Old 05-20-2010, 12:35 AM
OK....step by step
1. buy a new thermostat
2. Completely disassemble car
3. Reassemble car around new thermostat
sorry to be not so informative. It is an extremely complex process that pretty much involves removing the entire front end of your car. Just so you can access the stuff on the front of the engine that you have to remove to get to the thermostat.
I doubt that you will find anyone with the time and patience to spell it all out for you. The manual does call for some special tools (chopsticks anyone) but almost everything is adaptable. Good socket wrench, 10" extension, universal or a wobble...10 mm socket, 5 mm, 7 mm, 8mm hex sockets, set of torx sockets, BFH, 24mm socket, really big spanner (cant remember the size 1 1/4" maybe?)
bunch of other stuff
Old 05-20-2010, 01:56 AM
Cool thanks, Wasn't sure if the bumper and radiator had to be disco'd or not. Does the timing belt have to come off?
Old 05-20-2010, 08:17 AM
02A6Beau.. you just made my day. hahahaha
Old 05-20-2010, 10:03 AM
yes, the timing belt has to come off
may as well replace all of timing hardware while you are in there because you wont want to do it again anytime soon. I forgot, you need a 17mm socket too and I'm sure a few others that I can't recollect at the moment
Old 05-20-2010, 12:28 PM
hxgaser's Avatar
Thermostat replacement does require the timing belt to come off. Replace the water pump, tensioner, cam seals and etc while at it.
Old 05-20-2010, 01:42 PM
Quote:
^^^^^ ++++++++ Or you'll be sorry!
Old 05-23-2010, 06:03 AM
Hey, I DID THE JOB WITH A BUDDY SAT AND MADE MY OWN VIDEO!! Its on youtube. Please check it out and rate it.
http://www.youtube.com/watch?v=3JKy5DYhJmc
Old 09-22-2012, 07:14 PM
The '96 A4 V6 looks very similar.
The symptoms I have are:
1. Normal ramp up time to normal temp (gauge right in the middle/needle vertical)
2. It'll stay there for a bit then slowly get hotter (about 3/4 of the way to 'HOT')
3. It won't overheat, but it runs hotter than 'normal'
215,000 miles on it
I'm not concerned if it's the thermostat or pump. I've been trying for a while to get the time to replace the timing belt, which I know as of visiting here now, won't take me less than most of the day if not weekend. While doing that I was going to replace the pump, front main seal as it's weeping, and now the thermostat as it's right in there behind the pump. Oh what fun, what joy.
A while back I did a new fan without removing the radiator, lights etc. Is it really needed to do that for the timing belt etc, or is it just easier to do with all that removed, along with the reduced risk of hitting the back of the radiator with a slipping wrench etc?
Crewdogg - your video has been a great help in figuring out what's ahead - Thanks for taking the time and effort to do it
Old 09-23-2012, 03:05 AM
it is supposed to be doable by just moving the lock carrier forward enough to get at the front of the motor. In my opinion, it doesn't take much more work just to take the whole thing off. With the whole front end out of the way it is a lot easier to see what you are doing and get tools, your hands, whatever else in and out. Now if you were someone that did this kind of work every day and knew exactly what was where and how to get everything in and out with limited space I suppose it would be easier just to move the lock carrier, but since we aren't that (for the most part), I recommend taking the extra time to make the job as easy on yourself as possible.
good luck
Reply
Thread Thread Starter Forum Replies Last Post
thermostat change Lawrence12 B7 Models 2 09-11-2014 06:02 PM
Thermostat Change A8 BFM grease Audi A8 4 12-06-2010 12:40 PM
DIY to change thermostat on a '98 A4 1.8T xqwizit DIY - Do It Yourself 1 03-07-2009 11:22 PM
I need to change my thermostat pearlcfcivic Audi A4 44 01-21-2008 04:26 AM
how do you change the thermostat? lacrosse22 Audi A4 5 02-08-2006 09:25 PM
Tags
02, 28, 97, 99, a4, a6, audi, change, diagram, diy, engine, location, procedure, replace, replacement, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
