Sponsored by:
Sponsored by:
2000 A6 2.8L Hard Starting Problems, and now won't start
Old 11-08-2012, 07:56 PM
MicDaddy's Avatar
Default 2000 A6 2.8L Hard Starting Problems, and now won't start - maybe starter problem??
I am new as a registered member of the forums, but I have had 2 Audis and 2 VW Passats in the last 10 years, and I have been through these forums countless times. You guys know your stuff and that is why I'm here, I'm stuck! I have a 2000 Audi A6 Avant 2.8L, 150k miles.
This has been a slowly evolving problem with my car. Almost 9 months ago, I started having a hard start problem. It might take 10 secs of turning the engine over to start up. After reading these forums, I decided it was a fuel filter issue, so I replaced it. Problem went away for a while and my engine definitely had more get up an go. In the last week or so, the hard start issue returned, but hasn't been too bad until Tuesday morning.
In addition, on my way home from the store, the car started surging only during acceleration. From a stop, or while cruising, whenever I gave the car some gas, it jerked in accordance with my speed (slowly at low speeds, and more frequently at high speeds). On that trip, I started to go up a slight hill, which I have taken countless times, and the car completely died and hasn't been able to start again since. I think the two issues are related.
I have a vagcom (best purchase I have ever made), and I got a few engine codes among others, but no CEL light or OBDII codes. The full scan on Tuesday night is below. Since I saw that the camshaft position sensor was listed, I went ahead and replaced it. But the car still won't start and it isn't throwing any codes now.
I'm fairly mechanical but haven't done any major type of repairs on my own. Any help or guidance is appreciated!
Thursday,18,October,2012,06:55:28:39485
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 078-907-551-ATQ.lbl
Part No: 3B0 907 551 BA
Component: 2.8L V6/5V G 0050
Coding: 07252
Shop #: WSC 20205
VCID: 63CB5127F1CF85005C7
3 Faults Found:
17930 - Camshaft Adjustment; Bank 2
P1522 - 35-10 - Malfunction - Intermittent
16815 - Warm Up Catalyst; Bank 2
P0431 - 35-10 - Efficiency Below Threshold - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1
P1131 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 AK
Component: AG5 01V 2.8l5V USA 3132
Coding: 00032
Shop #: WSC 00000
VCID: 70E12E6B30392E98D15
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C392ADB8C31FAF8DDD
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
VCID: 234B1127B14FC5001C7
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 H
Component: Airbag Front+Seite 1002
Coding: 00106
Shop #: WSC 02335
VCID: 356FDF7F0FDB4BB0C23
3 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487
Component: E Lenkrad Elektronik D03
VCID: E9D7C30F93E35F5016B
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 980 LX
Component: C5-KOMBIINSTR. VDO D13
Coding: 02262
Shop #: WSC 65535
VCID: 860DE8B3A2BD90289B9
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
VCID: 3061EE6BF0B96E98915
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01561 - Left Rear Door
59-00 - Can't Unlock
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 A
Component: Sitzmemory D05
VCID: 2B5BF907D99F0D40A47
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 02325
VCID: E0C1DE2B60D91E18C15
3 Faults Found:
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor; Front Right
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00006
Shop #: WSC 02325
VCID: E5CFCF3F7FFB7B30323
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 195 A
Component: Radio D00
Coding: 00214
Shop #: WSC 00003
VCID: 1E3D20D39A2DE8E8339
End ---------------------------------------------------------------------
Old 11-09-2012, 10:08 PM
MicDaddy's Avatar
Just to follow up to my previous post, I have done some maintenance since I bought the car 19 months ago. plugs, fuel filter, air filter, regular oil changes, ran some seafoam in the intake about 6 weeks ago.
This week I have replaced a camshaft position sensor. Tomorrow morning, i'm going to start by checking on the fuel pump, fuel pressure, and some electrical testing. I also know that some vacuum lines are cracked, so I am going to start replacing the ones I can see that are cracked or broken.
Is there anything else I need to check?
Old 11-10-2012, 03:45 PM
MicDaddy's Avatar
Ok - another update. Some of my vacuum lines have broken, so I am replacing them. The camshaft breather hoses are a pain, but I'm going to do those next. Will vacuum hoses stop the car from starting?
I have also checked the fuel pump. I'm getting 10v while cranking and 1v while the ignition is on. I didn't hear anything from the pump. What is the best way to test if the fuel pressure is ok?
I had to stop for now because of snow. BTW - this is my daily commuter car, so time is a bit tight to get this fixed before Monday.
Thanks!
Old 11-13-2012, 02:28 PM
hxgaser's Avatar
I would think that it is your o2 sensor(s) that is(are) going bad.
Old 11-13-2012, 09:52 PM
Jeffla's Avatar
Since stalling going up the hill it has never started since?
Is the timing belt intact?
Old 11-14-2012, 12:03 AM
MicDaddy's Avatar
It started surging while accelerating, even slowly acceleration, then while going up a slight incline, it stopped and it hasn't started again. I don't know if the incline caused any issue, or if it is a coincidence.
The timing belt looks fine. I haven't replaced it since I've owned the car and it is probably due, but since that doesn't seem to be the immediate issue, I'm starting with what might be the cause. I'll circle back and replace the timing belt sooner than later.
I considered the O2 sensor issue, but that wouldn't cause the car to not start, it would just cause poor performance. Right?
After checking the voltage of the fuel pump, I unscrewed one of the fuel lines in the engine compartment and looked for any fuel while cranking the engine. and found none . So I figured that since I have voltage at the pump with no fuel pressure, the relay isn't the issue, so I purchased a fuel pump from Napa ($175+tax) and am in the process of installing it.
The current issue I'm running into is that the pump and cover are attached by two wires (black and yellow) and one hose. The other side of the cover where I need to attach the return hose is open with no nib on it to attach the hose. Do I need to transplant a copper nib from the old unit? They are really tight and copper so I'm trying to get it out without damaging it. Any tricks?
Old 11-14-2012, 08:10 AM
Jeffla's Avatar
The fuel pump does make sense. I read your 1st post too quickly. Personally I have not replaced my pump yet, and hope never to have to so I will be of no assistance (not like my 1st post was either). Auditech is a good resource if you can track him down.
Old 11-15-2012, 12:13 AM
MicDaddy's Avatar
Good news! After replacing the fuel pump, I got gas to the engine compartment and the car actual ran! So many, many thanks to this forum and to those who have gone before me. Your previous posts helped tremendously!
As a side note, make sure you specify which drivetrain you have to the part store. FWD and Quattro have two different gas tank covers. The Quattro needs the hose connections to be at an angle to fit. The FWD one is straight down and doesn't fit the Quattro. I have to return the wrong one that Napa sold me.
But I'm fairly happy. The engine didn't run smoothly because the intake was taken half apart since I'm replacing the vacuum lines. I felt that since I'm that far I might as well do a throttle body cleaning too. So I'll report back once all is done. Hopefully by this weekend.
Thanks again.
Old 11-17-2012, 01:17 AM
MicDaddy's Avatar
You guys WON'T BELIEVE THIS!! I finally got all the vacuum lines replaced, cleaned the throttle body and related intake parts. Got everything put back together, and went to start the car, and I heard a clunk and now the engine won't turn over.
It sounds like the starter motor is turning but the engine isn't. I also started smelling something getting hot. I have a feeling that the starter stopped engaging the motor.
Is the starter solenoid part of that or is a gear messed up? I'm thinking about calling around on Monday to machine shops and see if they can repair it, rather than replacing the entire thing. I can probably get a new one for around $200, but maybe it can be repaired for $80-100.
Any thoughts?
Old 02-09-2013, 01:17 PM
ottsrx7's Avatar
how tough was the fuel pump swap? I have a 99 a6 quattro and I think I'm going to need a new one. did you has to drop the tank or is there an access port in the floor pan?
Quick Reply: 2000 A6 2.8L Hard Starting Problems, and now won't start
