2000 A6 power mirror switch
hi, I let my folks drive my A6 and next thing I know the **** for the power mirror switch is no longer attached to the car. I got the piece for the non-memory seats. I removed the cupholder and I could see I was getting close, but still I'm reluctant to start yanking the thing off. Is replacing the switch something I can do myself or do I need to remove the pannels of the interpassenger space?
RE: 2000 A6 power mirror switch
Removing and installing mirror adjustment switch
Removing
Pull cover for centre console in -direction of arrow A- out of clips.
Note[/align]
The illustration shows a vehicle with manual gearbox.
Then pull cover for centre console slightly in -direction of arrow B-.
Detach cover for centre console.
Vehicles with manual gearbox:
Working from centre console, press out mirror adjustment switch -1- upwards by hand.
Unplug connector -2- at mirror adjustment switch -1-.
Vehicles with automatic gearbox:
Carefully insert screwdriver into recess on right next to the two centre console bolts.
As soon as screwdriver makes contact with bottom part of switch, press gently with screwdriver to prise out mirror adjustment switch -1-.
Installing
Install in reverse order, paying attention to the following:
Note[/align]
Make sure no clips are missing at front and rear of mirror adjustment switch.
[IMG]local://upfiles/12092/D9FFA536C9EB45719C0DDD976FE36E05.jpg[/IMG]
other picture added click on image 3
thanks a lot. I think I basically understand. I have the tiptronic gearbox, so I guess I'm going with the automatic description. I'm not sure how to pull out the cover for the center console so your explanation talks about arrows directions A and B I'm not sure if this talks about an illustration that is missing or if there are letters somewhere for me to find on the console. Either way, thanks a lot.
you're right. the only different in the switches is between those cars with memory possitioning for the seats and mirrors, and those without. This car is without.
My doubt though was as to how to remove the cover for center console in the automatic version.
I'm a new comer to this. I have a 2000 A6 also and the switch is broken. Do you have a diagram that shows how to remove the mirror switch? I looked at the other diagram that avant80@2.6 sent but doesn't show the clips. Hopefully you have something? Thanks!
coltoasty
08-13-2012 08:05 PM
ima_slap_joO
05-31-2008 09:55 PM
