AudiForums.com
Go Back   AudiForums.com > Audi Models > Audi A6
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Sponsored by Audi USA Parts
Reply
LinkBack Thread Tools Search this Thread
Old 04-11-2011, 02:22 PM
Default 2001 A6 2.8 Vacuum diagrams?
I looked all over and i cannot find any vacuum hose diagrams for my 2001 A6 2.8. Anyone have these to share? Thanks
Old 04-11-2011, 02:44 PM
Follow up. If anyone would take a picture of their vacuum setup that would work too. Thanks.
Old 04-12-2011, 12:04 AM
hxgaser's Avatar
Points: 5,050, Level: 45
Points: 5,050, Level: 45 Points: 5,050, Level: 45 Points: 5,050, Level: 45
Level up: 50%, 100 Points needed
Level up: 50% Level up: 50% Level up: 50%
Daily Activity: 2.2%
Daily Activity: 2.2% Daily Activity: 2.2% Daily Activity: 2.2%
Click the image to open in full size.
There is one under your hood too.
__________________
2004 V70R M66 - Current
2001 A6 Avant - Past
2.8 ATQ, Quattro, Tiptronic
Mods - Was chipped, but not now... Was using K&N, but not now...
Repairs - Too many to list! And you wonder why I still drive an Audi So I don't drive one now.
Old 04-12-2011, 08:01 AM
I found mine too, thank you. The only vacuum line disconnected was the reservoir. What is the name of the hard plastic line below? * Mine snapped, will it make the motor run horrible?
Old 04-12-2011, 11:57 AM
hxgaser's Avatar
That is your crank case breather hose. Yes it will make your car run rough. You can find it here.
Judging by the picture, I recommend that you pick up about 5 feet of 3/16" vacuum hose from local parts shop and replace all vacuum hoses. Just replace one at a time to track where it goes.
__________________
Old 04-12-2011, 11:59 AM
hxgaser's Avatar
Oh, don't forget to reconnect the vacuum reservoir line to the front of the car. The original plastic gets really brittle. I had to replace mine just over the weekend when I was replacing the valve cover gaskets. It pretty much disintegrated.
__________________
Old 04-12-2011, 12:15 PM
Quote:
Thank you very much for the replies. Picked up silicone vacuum line and will replace them tonight. Any idea what sensor this is to the right of the crank pulley? It has a nipple connector.. maybe it needs a pigtail or something?
Old 04-12-2011, 12:54 PM
chefro's Avatar
Oil temp sensor - it screws into the oil pump housing.
__________________
'95 12V - 167,400 miles - engine rebuild + ps fluid and ATF change; switched to Mobil1Syn 0W-30 at 158,200; Purchased Dec. 2008 @ 152,100 miles - Presently 168,900 miles
Old 06-14-2012, 09:43 PM
Points: 547, Level: 10
Points: 547, Level: 10 Points: 547, Level: 10 Points: 547, Level: 10
Level up: 94%, 3 Points needed
Level up: 94% Level up: 94% Level up: 94%
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Default 2001 A6 2.8 Vacuum Reservoir Location?
Sorry for posting to this old thread but you all had excellent info that sheds light on our problem. My daughter's 2001 A6 2.8L AT with 148K miles has a hard plastic 3/16"? hose above the driver's side engine bank going towards the front of the engine that is not connected. We plugged it with a rubber cap but it appears to go to the vacuum reservoir seen in the first diagram of this thread and highlighted by hxgaser's post. Can you tell us where this vacuum reservoir is located in the engine compartment? We can't locate it but we assume it is somewhere close to the driver's side wheel well or close to it. We don't have the Bentley manual for it and hope to get one soon. Thanks in advance for any help. Sincerely, Chuck
Last edited by chuck_eglin; 06-16-2012 at 08:48 AM. Reason: Left off important information required by moderators
Old 06-19-2012, 11:49 AM
hxgaser's Avatar
Take the driver side wheel off and remove the plastic wheel well cover. It looks like this.
__________________
Reply
Tags
2001, 28, a4, a6, audi, belt, brittle, diagram, hose, line, lines, plastic, routing, tensioner, timing, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
