Sponsored by:
Sponsored by:
2002 A6 2.7 quattro crankshaft position sensor how to replace
Old 08-28-2012, 04:48 PM
Wilsss's Avatar
Default 2002 A6 2.7 quattro crankshaft position sensor how to replace
Ok guys, so I am trying to replace the cps which I have located driver side engine block by the axle.
However, I can't see where the cable is going. I can't see where the other end connects.
so the one that goes in the engine has a 10 bolt. the other end is an electronic connection. (a plug with 3 teeth).
Sorry for my language but I am not familiar with the terms in English.
How do I replace it????
Pleaseeeee Heeeeelp!
Old 09-02-2012, 06:05 PM
CRuby's Avatar
Sounds like you found the CPS & single 10mm bolt. There should be a black wire mounted to it & that wire snakes upward on the back side of the block & over to the driverside firewall. There are several connectors mounted on a black plastic holder on the DS firewall. One of them is the CPS connector.
Old 09-02-2012, 10:05 PM
OGBULLYLOCDAWG's Avatar
17. G28
Looks to be behind the Expansion/Coolant Tank. Judging from the diagram, it should be the connector on the right (match with the new part if not sure).
mikestt
11-29-2012 05:12 PM
vpinargote
09-10-2011 10:53 PM
JPizano23
06-16-2011 07:25 PM
Hotdog
03-19-2010 11:50 AM
mcinp
01-03-2008 09:49 AM
Quick Reply: 2002 A6 2.7 quattro crankshaft position sensor how to replace
