Sponsored by:
Sponsored by:
2002 A6 2.7t bouncing idle, glowing downpipe?
Old 10-09-2013, 06:09 PM
69 lark's Avatar
Default 2002 A6 2.7t bouncing idle, glowing downpipe?
My wife's audi has been troublesome lately. Replaced timing belt and ICM's recently and car ran good for a couple of months. Now the car idle bounces up and down when cold and then after 2 minutes it turns to a rough idle with pops and what-not. Changed the MAF today and no change but I noticed that the driver side downpipe area was glowing red after only idling for 4-5 minutes. No driving or reving the engine. Any idea what could be going on here? Car was running good till she started it up in the morning and noticed the idle problem.
Old 10-10-2013, 01:03 PM
69 lark's Avatar
So, thought maybe one of the new ICM's went bad so I replaced each one with one I knew was good and no change. Car has all new plugs and coilpacks installed about 4 months ago. Please say this doesn't have to do with the timing belt. I do NOT want to go through that again.
I don't hear a vacuum leak but could that be a possibility?
Anyone in central FL with a vag-com?
Old 10-10-2013, 02:21 PM
Nebuchadnezzar's Avatar
This could be a lean condition causing the hot exhaust temps. Perhaps faulty EGT sensor(s)?
Old 10-11-2013, 09:06 PM
69 lark's Avatar
Still no luck. Can't figure out why the idle bounces up and down at start up.
Old 10-11-2013, 09:51 PM
The irregular idle maybe caused by a vacuum leak. You may not hear it as the sound of the engine and fans may not allow you to do so.
Old 10-11-2013, 10:07 PM
ManyAudis's Avatar
It is also possible that the cams jumped one tooth on the hot side and the exhaust valves are opening too soon. I would double check the t-belt timing. Get this fixed quick or you may kill the turbo on that side.
Old 10-11-2013, 10:11 PM
69 lark's Avatar
Well, I'm definitely not driving the car any and only letting it run for 3-4 minutes at a time trying to find the problem. How do I check the timing? About to buy a vag-com. Would that show if it is a timing issue?
Old 10-12-2013, 12:18 AM
Good call on that one.
OP: Do you have a CEL on the dash?
Old 10-17-2013, 07:55 PM
69 lark's Avatar
So I bought a Vag-Com. Here's the readout..
9 Faults Found:
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-10 - Efficiency Below Threshold - Intermittent
17972 - Throttle Actuator (J338)
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
16487 - Mass Air Flow Sensor (G70)
P0103 - 35-00 - Signal too High
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16688 - Cylinder 4
P0304 - 35-00 - Misfire Detected
16690 - Cylinder 6
P0306 - 35-00 - Misfire Detected
16689 - Cylinder 5
P0305 - 35-00 - Misfire Detected
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
16686 - Cylinder 2
P0302 - 35-00 - Misfire Detected
Readiness: 0000 0000
Old 10-17-2013, 07:57 PM
69 lark's Avatar
what's causing all the misfires? New MAF, new ICM's, new coils, new plugs..
Quick Reply: 2002 A6 2.7t bouncing idle, glowing downpipe?
