2002 Audi A6 Quattro Fault code PO741 - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 09-18-2007, 09:35 PM
Default 2002 Audi A6 Quattro Fault code PO741
Can anyone shed some light on this fault code? I have tracked down the TSB 320501 but only a summary which states torque convertor performance or solenoid valve stuck shut. The car runs fine and since mechanic cleared the code it has not come back. TSB also states no performance issue with this fault. New Torque convertor is $3,500 and up. Do I need to replace it or is this just a phantom code? Replacement is significant potion of the car's value. Any help would be apreciated.
Old 09-19-2007, 12:49 AM
auditech79's Avatar
Default RE: 2002 Audi A6 Quattro Fault code PO741
The best you could hope for is the TCC doesn't get stuck again and cause a check engine light.
If it happens again the torque converter has to be replaced, end of story.
Leaving a faulty one in there is not healthy for the transmission.
Reply
Thread Thread Starter Forum Replies Last Post
2002 Audi A4 3.0 Quattro scan code PO431 silver a vier B6 Models 1 09-17-2011 04:04 PM
Fault code P1744 on my A4 1.8t Tiptronic Quattro ssingh General Tech 0 02-10-2011 09:03 AM
Fault code P1744 on my A4 1.8t Tiptronic Quattro ssingh B6 Models 0 02-10-2011 08:59 AM
HELP! 1990 Coupe Quattro misfire knock sensor fault code dqpb tturboeattrouattro Classic Audi 2 04-25-2009 03:51 AM
Code po741 jkor2003 Audi A6 10 01-26-2009 11:26 AM
Tags
2002, 320501, 741, a6, audi, code, converter, performance, po741, quattro, remove, replace, tcc, torque, transmission, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
