2003 A6 3.0 Oil leak burning smell
I have a 2003 A6 quattro 3.0 v6. I just got it with 94k on it and it has been driving good. Since I picked it up I have noticed a Oil burning smell when I was driving. I keep checking the oil level and it has not gone down. I just did a tune up and replaced 3 coils and all the spark plugs. I had a code for multiple misfires and it called out 3 cylinders so I replace those coils. Anyways back to the issue. I think it has a slight leak on the valve covers and it drips on the manifolds? It was smoking a little yesterday after a long drive. You could only see the smoke when you raised the hood imediately after driving. Any ideas what wrong? Valve cover gaskets?
Oh and by the way Great forum!!
I was having this same issue with my 04 3.0 quattro. I could smell the burning inside the car and could also see smoke that would quickly dissipate when I opened the hood. The culprit was indeed the valve cover gaskets, which were recently replaced along with the timing, t-stat etc., but the mechanic did a poor job. Took it back in and had him re-install new gaskets. No more smell or smoke and its been over 6 months. Of note, I could see the oil stains along the valve covers, mainly toward the rear. Oil was dripping on the exhaust and burning up. I also cleaned the hell out of the valve covers and removed any oily/dirty gunk stuck in the bolt heads and anywhere else I could see just to make sure it wasn't old oil residue burning up.
Hopefully yours will be as easy a fix as mine. Good luck.
seanpawn
02-10-2009 01:26 PM
