Sponsored by:
Sponsored by:
2005 A6 ABS code / brake presure sensor failure?
Old 10-21-2013, 10:29 PM
johnscot's Avatar
Default 2005 A6 ABS code / brake presure sensor failure?
I'm getting dash lights and beeps warning of ABS / ESP and Parking Brake failure. Shop runs the diagnostic and comes up with codes 01316 - ABS control module fault and 01435 brake pressure sensor 1 failure. Shop says it's the ABS control module and will need new ABS brake hydraulic pump. Any chance that they're wrong? I had brakes (pads and rotors) replaced in front just before getting the errors (at a different shop) and the current shop asks me if the prior shop did brake fluid flush / fill .. they say if the shop did not do that.. could have caused debris to clog a valve in the ABS and cause its failure. Sounds credible... but how much of a case do I have .. it was a dealer that changed the brakes.. and I see no mention of brake fluid flush and fill. The dealer that did the brake work only commented on invoice: "Replaced front pads and rotors, torque to audi specs per elsa web specs. Adjusted brake fluid level". Could they have caused the ABS failure by not doing a flush and fill of brake fluid? Asking a lot here.. I know. Thanks for any feedback.
Audi_Skydiver
12-31-2015 09:13 PM
mogwai88
02-17-2014 07:23 PM
Dungar46
03-10-2010 09:30 AM
AudiKP
09-12-2005 12:53 AM
Quick Reply: 2005 A6 ABS code / brake presure sensor failure?
