2005 a6 - centre brake light
2005 a6 - centre brake light/ESP/ABS
I'm getting a loud beep and a yellow "Brake Light" error message display on my dash. During the beep it also says "Centre Brake Light" in red but goes away soon after the beep stops. The centre brake light works sometimes which leads me to believe that it isn't the light itself (but I'm not ruling that out just yet). Could this possibly be a faulty brake switch or being caused from the cold winter weather?
Also, the ESP/ABS recently came on...could this all be related?
Note: the other two brake lights are working properly
Thanks in advance!
Thanks in advance!
sounds like your loosing a firm connection in the cold weather.
You have to find where the center connects into the harness unplug it pinch the females a little with a small pick and clean the males with a nail file, use di-electric grease and reassemble.
Thanks Jackmup. I haven't gotten around to looking into this more until today when the ESP light came on followed by the ABS light. Does all three of these lights now being on point to a problem with the brake light switch?
After doing some research I tried to replace the brake light switch but that didn't do anything...I hooked up the VAGCOM and it came back with a long list of errors (the diagnostics was taken before replacing the switch...any ideas??):
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2A50875EFC97
2 Faults Found:
18975 - Low Pressure Fuel Sensor (G410): Intermittent
P2543 - 009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 79
Reset counter: 40
Mileage: 149556 km
Time Indication: 0
Date: 2012.01.03
Time: 18:46:45
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 81.0°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 40
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 130.8 mg/str
Temperature: 70.5°C
Idle
Load: 20.4 %
Speed: 0.0 km/h
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Shop #: WSC 02327 785 00200
VCID: 2D5A8C42CD79
2 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
Hex Value: 0x3800
Hex Value: 0x4006
Hex Value: 0x001C
Hex Value: 0xB1AD
Hex Value: 0x00FF
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 154315 km
Time Indication: 0
Date: 2012.03.04
Time: 13:17:38
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC1AD
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300111724
Coding: 0000011
Shop #: WSC 01405 444 999999
VCID: E3CEAA7A5B3D
Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H38 0040
2 Faults Found:
01179 - Incorrect Key Programming
000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 118969 km
Time Indication: 0
Date: 2010.12.03
Time: 11:58:12
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 31
Reset counter: 51
Mileage: 112580 km
Time Indication: 0
Date: 2010.10.13
Time: 19:28:37
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Component: SDAR
Serial number: AUZ4Z7D3007298
Shop #: WSC 00000 000 00000
VCID: 2648736EE88F
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Mileage: 132292 km
Time Indication: 0
Date: 2011.05.18
Time: 09:59:14
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H44 0570
Revision: 00000000 Serial number: 378BV057516528
VCID: 356AA4222529
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 49
Reset counter: 0
Mileage: 111403 km
Time Indication: 0
Date: 2010.07.23
Time: 12:11:50
Freeze Frame:
Bin. Bits: 0100
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01002712740000
Coding: 0423997
Shop #: WSC 02335 785 00200
VCID: 2C5C8146F663
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
1 Fault Found:
01503 - Bulb for 3rd Brake Light (M25)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 227
Mileage: 145286 km
Time Indication: 0
Date: 2011.11.08
Time: 08:47:33
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: DDBA9C827D59
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 7
Reset counter: 9
Mileage: 153512 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:12
Freeze Frame:
Voltage: 13.25 V
Count: 236
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000020139
Shop #: WSC 02335 823 00000
VCID: 234E6A7A9BBD
Part No: 4F0 915 105 C
Component: von VA0 2502100427
Coding: 344630393135313035432056413032353032313030343237
Shop #: WSC 00000 384 00290
5 Faults Found:
02277 - Quiescent Current Stage 6
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Mileage: 132289 km
Time Indication: 0
Date: 2011.05.17
Time: 10:11:34
00992 - Consumption Cut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 117360 km
Time Indication: 0
Date: 2010.11.20
Time: 15:35:15
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 151652 km
Time Indication: 0
Date: 2012.01.30
Time: 04:43:26
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 132289 km
Time Indication: 0
Date: 2011.05.17
Time: 10:11:14
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 152165 km
Time Indication: 0
Date: 2012.02.06
Time: 16:45:09
End ---------------------------------------------------------------------
VCID: 2A50875EFC97
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 79
Reset counter: 40
Mileage: 149556 km
Time Indication: 0
Date: 2012.01.03
Time: 18:46:45
Freeze Frame:
RPM: 672 /min
Temperature: 81.0°C
Idle
Pressure: 4.9 bar
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 40
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
RPM: 672 /min
Temperature: 70.5°C
Idle
Load: 20.4 %
Speed: 0.0 km/h
Coding: 0020895
VCID: 2D5A8C42CD79
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 227
Mileage: 153518 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:10
Freeze Frame:
Hex Value: 0x3800
Hex Value: 0x4006
Hex Value: 0x001C
Hex Value: 0xB1AD
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 11
Mileage: 154315 km
Time Indication: 0
Date: 2012.03.04
Time: 13:17:38
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0004
Hex Value: 0xC1AD
Hex Value: 0x00FF
Coding: 0000011
VCID: E3CEAA7A5B3D
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 118969 km
Time Indication: 0
Date: 2010.12.03
Time: 11:58:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 51
Mileage: 112580 km
Time Indication: 0
Date: 2010.10.13
Time: 19:28:37
Component: SDAR
VCID: 2648736EE88F
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Mileage: 132292 km
Time Indication: 0
Date: 2011.05.18
Time: 09:59:14
VCID: 356AA4222529
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 49
Reset counter: 0
Mileage: 111403 km
Time Indication: 0
Date: 2010.07.23
Time: 12:11:50
Freeze Frame:
Bin. Bits: 0100
Coding: 0423997
VCID: 2C5C8146F663
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 227
Mileage: 145286 km
Time Indication: 0
Date: 2011.11.08
Time: 08:47:33
Revision: C63C0030
Coding: 0005022
VCID: DDBA9C827D59
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 9
Mileage: 153512 km
Time Indication: 0
Date: 2012.02.21
Time: 19:03:12
Freeze Frame:
Voltage: 13.25 V
Count: 236
VCID: 234E6A7A9BBD
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 132289 km
Time Indication: 0
Date: 2011.05.17
Time: 10:11:34
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 117360 km
Time Indication: 0
Date: 2010.11.20
Time: 15:35:15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 151652 km
Time Indication: 0
Date: 2012.01.30
Time: 04:43:26
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 132289 km
Time Indication: 0
Date: 2011.05.17
Time: 10:11:14
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 152165 km
Time Indication: 0
Date: 2012.02.06
Time: 16:45:09
gertron30
02-01-2010 06:34 PM
