Sponsored by:
Sponsored by:
C4 - Sway Bar bushings
Old 03-04-2011, 01:57 PM
chefro's Avatar
Default C4 - Sway Bar bushings
As the weather starts warming up, I'm getting closer to pulling the engine and it would be a great time to change all the bushings around - c. arms, sway bar, and even (maybe) subframe.
Although I can wait until I have the car apart to measure the bar's diameter, or brace myself for calling audi dealer(s) around, does anyone have by accident the right part number for the sway bar bushings?
It would be greatly helpful.
Thanks in advance.
(don't know if it's really needed, but C4 2.8 12v, non-quattro)
Old 03-04-2011, 02:24 PM
UberTeile's Avatar
I'll help ya' out w/the outer SB bushings & washers...
4A0407181A - outer bushing(x4)
4A0407201 - washer(x4)
For the inner bushings, let me know if it's a FWD sedan or wagon.
UberTeile
Old 03-04-2011, 03:25 PM
chefro's Avatar
Thanks a billion, Uber.
Is a FWD sedan - AFC engine (VIN A)
The inner bushings come with the control arms, it looks like- but if I have the correct PN I can just buy them separately, along with the outer bushings. (I've noticed they're widely available - at least at ECS Tuning and AAutohaus).
If the ball joints are still good, then I may just try to replace the bushings since I have access to a hydraulic press. Can't relly tell though until I pull it apart.
At least I know the c.arms outer bushings on both sides are cracked, and perhaps I definitely need to replace the sway bar ones.
Thanks again.
Old 03-04-2011, 03:39 PM
UberTeile's Avatar
If you check around you might be able to find them in polyurethane. I remember that was a nice upgrade several years back.
todvol12
08-10-2009 01:09 PM
Yentemad
11-14-2007 08:01 PM
granite statah
09-15-2007 08:55 PM
2k2nyc
12-09-2005 04:15 PM
audifan
12-27-2004 03:13 PM
Quick Reply: C4 - Sway Bar bushings
