2006 A6 Brake sensor wire cut
The brake sensor wire on my A6 was pinched and cut. My mechanic says I need new pads.
Can I just cross the wire or something to turn the warning light off and live without the sensor?
Thanks.
Pat.
Thanks.
Pat.
Four options
1. Reconnect the wires.
2. Replace pads
3. live with warning on dash
4. Jumper the wires together.
Do 2 if the pads are worn
Do 3 if you like lights
If you do 4 make sure you check the pads.
If the wires are long enough 1 is the best choice - use a bit of solder and heat shrink tubing to insulate the wires.
2. Replace pads
