Sponsored by:
Sponsored by:
98 A6 Quattro Automatic Trans issue
Old 07-29-2013, 03:26 PM
ninthmyers's Avatar
Default 98 A6 Quattro Automatic Trans issue
My A6 gave out in Vegas. There was a sound like a manual popping out of gear and I lost everything. No park, reverse or any forward gears. I push the accelerator and the speedometer will register but the car is stationary. After a bit I went back to the car and it went into gear but quickly popped out again (within 30 seconds of being in gear.) HELP!!! is this a torque converter, or an T-case or something other than a transmission rebuild?
Old 07-29-2013, 09:04 PM
Nebuchadnezzar's Avatar
This sounds like a torque converter issue. Do you have access to vagcom and can scan the controller for codes?
Old 07-30-2013, 01:00 PM
ninthmyers's Avatar
yes when the car arrives from Vegas (after scalding it for loosing all my money there) I will give it a scan.
Old 07-30-2013, 05:17 PM
Well, I hate to break the news to you but unless you're going to do the work yourself, you might want to stay in Vegas until you hit the jackpot. (Assuming your torque converter is shot)
Old 07-30-2013, 07:20 PM
ninthmyers's Avatar
I will be doing this myself. I am lucky I have a friend that owns a transport company. As far as the torque converter I may as well do a trans since I will have it out. I have found used ones for less than a grand with half the miles I have.��
bixing
05-30-2010 11:46 PM
ericrb76
12-02-2008 04:39 PM
molotovman
05-09-2008 02:43 PM
jmorris1@vt.edu
03-31-2007 01:04 AM
milutin1
01-31-2007 11:42 AM
Quick Reply: 98 A6 Quattro Automatic Trans issue
