A6 2.7t S-line Oil Leak
Hello All -
I have an 04 A6 2.7t S-line with 58K miles and I'm sure it has a small oil leak but don't know what's leaking. I see nothing from top down but have noticed a burning oil odor after driving it for a while. Just returned from a road trip from IL to FL and back; while stopped at rest areas I noticed some smoke rising up from the front left (passenger) side of the engine close to windshield. The dealer has previously checked the car but said they couldn't find anything. Any ideas? Thanks in advance!!
Welcome to the club!
ToryG,
As a proud owner of an Audi you should start reading the top rated and located:
"tips and suggestions for the new 2.7t owner"
If there are no answers to your particular case=> we would be happy to help as much as we can!
ToryG,
Hello All -
"front left (passenger) side of the engine close to windshield" precludes the cam seals, which are at the front of the engine. Valve cover gasket. Cheaper and less of a pain to install, but still a pain.
Bob
Bob
OHH I didn't see close to the windshield! I believe Bod is correct unless it is a lower cam seal. Gaskets are commonly paper in these cars -_-
It also depends on which left he is refering to. Standard auto nomencalture has the left on the US/German driver's side of the car. Of course, in British/Japanese/Australian, the driver's side is the other side....
In either case, it isn't the cam seals. If he has his left (driver's) confused with his right (passenger) side and he means his right side, then it could also be the cam tensioner seal.
Of course, either of these could also mean the Spyder pipe needs replacing.
Bob
Bob
