A6 - Drivers door sensor
98 A6 quattro -
My door sensor on the drivers door is not working. When I open the door the interior lights don't turn on, but if I open another door the interior lights do turn on. Also on the display will not show if that door is open and the car is running but, if I open another door with the car running the display shows if other doors are open. Any ideas what to check?
Thanks
Thanks
The switch is located in the latch mechanism inside the door. To get it from a dealer you need tobuy the entire assembly which is about $230 I found a used assembly on ebay for $45 when mine went bad a few months ago and so far its working fine.
It is a bit of a pita to change out but not terribly hard
Pretty good quote on the latch. It's 4B1-837-015-H for 194.25 and in stock. Plus about 9-11 dollars shipping depending on where you are. If you are interested in a new one please let us know. Thank you, Jeff.
The motor the unlocks and locks the door is also not working, I have to use the key to lock and unlock the drivers door. Would changing the latch assembly fix this issue or will I need another part?
Also, on my passenger door I have to pull on the handle twice to get the door to open, would changing the latch assemble be the fix for that issue as well?
Thanks
Thanks
I would say yes and yes do a quick check to see that you do not have any broken wires in the area where the harness goes from the chasis to the door (pull the rubber boot back and give a firm pull on the individual wires to see if any are broken) and if not more than likely the latch mechanism is bad the lock motor, door switch and the door latch are all included in the latch assembly.
Just ordered a used latch assembly. I called a place to swap it out and they quoted me 3 hours. Is that a lot for this job (seems like it)?
Also, if I did just do it myself, two questions. 1) How bad could I mess it up (worst case scenario) and 2) How difficult is this swap really. Some places say it is no problem. Other warn about clips, wires, removing the lock and whatnot being an issue. I don't do much work on cars so swapping out the turn signal relay and, more recently, the ABS module, were a big deal.
Thanks!
Thanks!
Thanks!
Thanks!
