ABS ESP light ON and OFF - What else i can do???
Hi guys,
Here is my problem on my 03 3.0 quattro A6.
The ABS and ESP light comes on every 2nd time i start the car. If it comes on when i start i stays on until i turn it off. When i start the car and the light isn't t on, then it will come on within 1min.
I have read a little about it and i have checked my brake lights ( they are working OK ) i have cleaned abs sensors.
What else can i do before taking the car to the mechanic???
Btw: ABS light dosen't come with Brake light so it is not ABS module problem
Yeah i guess i ll get it scaned with VAG tuesday and c whats cousing this probblem.
What if Alligment is off, would this couse the lights to come on? My car is pulling to the right after new tires and brakes were installed 3 month ago.
I have the same problem with my 2003 A6. This started about 2-3 years ago. Both lights still come on once in awhile and then go off, but I have not been able to find out what the cause was. Each time I took it in to Audi, the lights would go off and they told me there were no codes and everything was fine, so I am lost at what the cause is.
From what I have read, it may be the ABS module. This is a problem with this car from what I hear. I researched on-line and found a place that would do a refurb of the ABS module (remove it from you car and send it out) for $289.00 with a life-time warranty. The company is called ATE (www.autoecu.com).
Good luck and let me know if you find out the cause.
Finally thanks to your help and visiting few shops i got the probblem diagnosed.
I took my car to local German Center and they serviced the car for previous owner ( lucky me ) and here was they told me:
The ABS module is sending the code that front right abs sensor is bad, the previous owner got it replaced and nothing changed. So they took it to Audi dealer, same think, got it scaned, replaced and nothing changed.
She came back to German Center and they find out that the ABS module is bad. Usually when the module goes bad the ABS and Brake light come on. In this case is sending misleading information due to internal problem.
Hi folks I've finally got the true final answer for almost all around here.
Please try!
https://www.audiforums.com/forum/sho...3&postcount=11
Here you are!
Please try!
Here you are!
