Sponsored by:
Sponsored by:
changing language display..
Old 08-29-2008, 01:17 PM
h00kah123's Avatar
Default changing language display..
i own a 2004 a6 2.7 sline package, everytime i start the car up.. her display shows up in french..the manuals doesnt tel me how to change..can anyone help me at this please?
Old 08-29-2008, 01:22 PM
oc_audica's Avatar
probably need change the ecm code to usa via vag-com
Old 08-29-2008, 01:41 PM
h00kah123's Avatar
vag-com?im totally new to all this..can you please brief me ?
Old 08-29-2008, 02:16 PM
oc_audica's Avatar
it is a communication cable that connects to your OBDII port and can read fault codes, log stuff, change module settings etc...
http://ross-tech.com/
Old 08-29-2008, 04:18 PM
h00kah123's Avatar
thank you..
Old 02-09-2022, 06:27 AM
Billos's Avatar
Banned
I recently moved to another country, and the change of language is still negatively affecting me. I can't get over my shyness and language barrier.
Old 02-09-2022, 06:33 AM
Ultimer's Avatar
Don't worry, I think most people who move to a new country or just start speaking a different language go through this stage. When I started learning Russian, of course, I taught it with online Russian tutors, which helped me a lot, because I specifically chose a native speaker. But nevertheless, I tried to communicate with Russian guys more often, I found them on the Internet and started to chat so as to overcome the language barrier. You just need more practice.
Old 04-14-2022, 07:12 AM
audimarx's Avatar
Banned
Oh, I had the same problem with my phone. Well, I was lucky it switched to German, and I knew the basics of it, but I'm not sure about it now.
Old 04-18-2022, 06:52 AM
Billos's Avatar
Banned
I keep you informed: over the past two months, the situation has changed a lot for the better!
Old 04-18-2022, 06:57 AM
JAcobRavel's Avatar
Have you ever thought about improving your german? I think if you know the basics, it'll be pretty easy for you to improve your language skills, and I can even recommend you check out the best apps to learn german fast. Personally. I use them as well to learn this foreign language, and I can say that they work pretty well.
Quick Reply: changing language display..
