abs module faulty or bad brake sensors?
posted this a few weeks back and since have taked to the abs module rebuild guys. i flat out asked them if there is no brake sensor , since i read just to clip and cap wires pre-sensor when not using oem pads with sensors, if this would make the abslight come on. no one there knows! thier origional thought was you have to have a circuit through the sensor to communicate with the abs module and without it the abs module won't work. now i'm totally confused??? can anyone clarify this as fact or fiction before i send them my module? again , i clipped the wires before the sensor and just removed it and then capped the wire...........thanks all!
RE: abs module faulty or bad brake sensors?
ABS is a totally different system to break pad ware sensor so doubt it would make the ABS lights come on, you can get both none sensor and sensor break pads and both dont effect the abs system as long as you do as the paper says ( provided in the package )
