Audi a6 3.2 V6 leaking water?
So I noticed my car has been leaking a clear liquid (not oily or anything) in assuming its just water but it's leaking quite a lot on the left side right in front of my wheel from a little opening on the part that goes all around the wheel and is attached to the car (forgt what it's called) let me know what you think!!!!
When you leaking that implies water leaking into the interior of the car. Your description sounds like external drainage. Sorry not to be to picky, but there can be interior leaks related to a number of issues. I cant say what you are looking at, but try to follow the hose back into the car to see where it goes.
If it is a fixed hose through the fender well, it is most likely some water from AC or other area. You can test by pouring a little water on the cowling by the winshield to see where the water comes out. Also there are drains in you sunroof. Open sunrooof, parked on level ground pour a little water into sunroof tray, you should see water drain out.
hofmeister
06-03-2006 01:40 AM
