Audi A6 Headlight problem
I have an Audi A6 2tdi, registered 2008. My problem started this morning. A sharp beep followed by a light bulb with a red cross across it on the speedo cluster lcd display. I noticed that the front nearside (Left) headlight bulb was out. I have renewed the bulb but the fault is still there. I have checked various fuses mentioned in the hand book. The off side light works perfectly. Has anyone got any ideas. Is it possibly a module/relay or just a fuse I have not identified. Incidently, the lcd display also shows that the car is due a service.
Any help would be most appreciated.
Amrik,
Hey man I've had my A6 for 3 weeks now and have the same issue. But after my loud *** deffening beep I get an adaptive light failure. I have no idea what it means. But if I find out... I'll let you know.
would like to permanently disconnect adjustable headlight leveling control warning light on Audi Allroad A6. Once I know this is actually possible, would like to do headlight upgrade to HID LED running light configuration. Have heard there's a way to tell programming that the car is now equipped with Halogen and that the level motor and warning light will be dead. Appreciate any / all info necessary to manage this trick... thxs...
