Auxiliary Fan comes on and won't turn off - AudiForums.com
Reply
Thread Tools Search this Thread
Old 01-27-2011, 09:21 AM
Default Auxiliary Fan comes on and won't turn off
I have a 2000 Audi A6 Avant Quattro that I recently purchased. I am having issues with the Auxiliary cooling fan. It is coming on right after starting the car, even though it is cold out and the AC is not running. It is running on high, sounds like a jet when on and when I stop the car, the fan drops to low speed but continues to run for several minutes after the car is off. I don't know why the fan is coming on in the cold weather, my understanding is that it supposed to come on when the AC is running and engine is running hot. I did recently replace the engine coolant temperature sensor to adress cold starting issues. I searched the forums and found some complaints about the fan not coming on, but I have a different situation here and was hoping for some input on how to diagnose the problem.
Old 01-27-2011, 11:21 AM
hxgaser's Avatar
There is another temperature sensor that activates the fan. It is located on the lower coolant hose next to the radiator on the passenger side. Try replacing it and see if it solves your issue.
Reply
Thread Thread Starter Forum Replies Last Post
Replacing auxiliary fan jj2345 Audi A6 8 10-20-2011 11:37 AM
A3 Auxiliary Fan tsells1 Want to Buy 0 11-05-2009 01:24 PM
97 A6 Auxiliary Jack nepsa Electronics 3 08-15-2009 11:37 AM
Auxiliary Fan drobrt S Car Model Line 1 11-16-2007 01:23 PM
changing the auxiliary fan KloepferN Audi A4 7 06-06-2005 03:16 AM
Tags
2000, a3, a6, audi, car, continues, cooling, fan, fans, read, running, scanner, starting, switch, tt, turns, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
