ball joint
ball joint
so the upper front ball joint on the front passenger side needs to be replaced... well actually the whole control arm cause as you know you cant just replace the ball joint. Any recomondations on where i should purchase one from or what brand i should buy. thanks for all you ideas
if you want a good arm, blauparts.com they use mann/febi.
if you want some cheap arms...fcp groton. i believe they are chinese. but 33 dollars each.....and they are supposedly heim bearings.
i ordered a set of pass side forward/rearward from fcp groton a couple days ago just to see if they look good. one problem though. my pass side forward ball joint bolt is seized to no end so we will see
