AudiForums.com
Go Back   AudiForums.com > Audi Models > Audi A6
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Sponsored by Audi USA Parts
Reply
LinkBack Thread Tools Search this Thread
Old 04-19-2010, 02:17 PM
Default Brake Pad worn warning light
Hi,
I have got a 2002 Audi A6 Quatro. The yellow brake light (O) started flashing a couple of days back. Now the car is not accelerating properly. I need to push the gas pedal a lot to move at 45-50 MPH. I have new front pads and rotors installed a few months back.
Any ideas on what could be the issue? Thanks in advance for the help.
Old 04-19-2010, 11:28 PM
yeaa the wiring that connects to the sensor is probly corroded and destroyed...mine was destroyed pretty bad, but all it is, is 2 wires that connect to the brake pad sensor, its very obvious when u remove the front 2 wheels (only the fronts have them) and the wire will probly just be hanging there. You can either reroute the wires back into the sensors or short the 2 wires together and the light will go away, i went for the shorting of the wires...was alot easier and i can usually tell when my pads are low just from driving.
Your accelerating problem is not brake pad related, do you have a CEL (check engine light)? if so or even if not, take it down to autozone and get it scanned real quick to see if any codes pop out, or even better borrow or buy a vag-com
__________________
Use to have a 00 a6 2.7t, started falling apart bad, traded it in for an 07 a4 2.0t, best idea of my life. Current mods: debadged, test pipe, and air intake.
Old 04-20-2010, 11:12 AM
Thanks for the valuable inputs!
CEL is not on! The accelerator problem is happening after the Brade Pad Warning Light started coming.
Thanks,
Old 04-20-2010, 01:30 PM
Points: 6,483, Level: 52
Points: 6,483, Level: 52 Points: 6,483, Level: 52 Points: 6,483, Level: 52
Level up: 67%, 67 Points needed
Level up: 67% Level up: 67% Level up: 67%
Daily Activity: 1.1%
Daily Activity: 1.1% Daily Activity: 1.1% Daily Activity: 1.1%
The only way the acceleration problem and pad sensor would be connected is if the new brakes were incorrectly installed and the front brakes were dragging. BUT you would have felt that long before the light came on.
You gotta figure out if the pad light is due to worn pads, bad connectors, or broken wires. If it is worn pads someone did a poor job or your riding around with a foot on the gas and the other on the brake.
__________________
1997 A6 Avant with over 250,000 miles - Now dead
2007 Dodge Grand Caravan SXT - 2002 Dodge Caravan
1999 Mercury Sable Wagon w/48K miles
1919 Model T Ford Beach Wagon - AKA Woodie
Reply
Tags
07, 2002, a6, audi, brake, indicator, light, long, pad, pades, pads, q7, warning, worn, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
