Sponsored by:
Sponsored by:
brake questions
Old 11-05-2012, 06:57 PM
jamesbaker1975's Avatar
Default brake questions
i recently purchased a a6 2.7t and need to replace the front brake caliper but all the auto stores tell me its a single piston but i actually have the dual piston . is this normal but when i look on line i can find the caliper listed under s4 thanks for the help
Old 11-05-2012, 07:08 PM
hxgaser's Avatar
Not trying to question, but why do you need new calipers? Are the pistons leaking or something?
Old 11-05-2012, 07:15 PM
i got the car and went through the glove box found receipts for repairs and they put on the receipt recomended a new caliper and im getting some kind of vibration and was just going to start there. but the vibration stays constant as i drive . at first i thought maybe a busted belt soo i rotated the tires and still there
Old 11-05-2012, 07:25 PM
hxgaser's Avatar
I doubt that it will be your calipers. Your rotor maybe... But it should only vibrate when you are using brakes.
FYI, calipers are pretty bullet proof.
If you are noticing vibration at all speeds, then I would start with tire and tire balancing, or wheel bearing issue. Rotating tire will not address balancing issue. It may move the vibration to another axle.
Anyways, if you think that your wheels and tires are properly balanced, then I would consider doing a visual inspection of the suspension components including all the bushing and etc.
Old 11-05-2012, 07:31 PM
will do thanks for all your help.. i did find on the driver side the upper arm ball joint had alot of play i am looking into changing both sides upper and lowers. but the noise is on the pass side but once again thanks for the help ill look into the wheel bearings thanks
Old 11-08-2012, 06:30 AM
george1546's Avatar
Just another suggestion, my car too was vibrating/shaking when braking, only braking not to long ago.
Turned out the discs (front only) needed to be filed and straightened, cost 12 bucks per disc to fix.
This happens when the disc is heated and cool water suddenly hits the discs causing the surface of the disc to uneven hence causing vibrations when braking.
Filed the discs, all good now.
good luck.
Old 11-08-2012, 06:02 PM
good luck.
thanks ill look into them
audisnob
12-27-2013 02:49 PM
aeeroN
05-26-2012 06:38 PM
olstyn
07-06-2011 02:54 PM
NeXeA500
03-21-2009 12:15 PM
Quick Reply: brake questions
