Sponsored by:
Sponsored by:
C6 & C7 diagnostics and coding via a smartphone app: Carista OBD2
Old 03-20-2015, 01:52 PM
Carista's Avatar
Former Sponsor
Default C6 & C7 diagnostics and coding via a smartphone app: Carista OBD2
Hi all, I'm happy to announce that we've just released Carista for iOS, which lets you customize your car (a.k.a. change "adaptations" and "coding"), as well as do detailed diagnostics of all ECUs in the car, including the VAG-specific ones like the airbag, ABS, etc. You don't need any expensive hardware; Carista works with standard ELM327 devices (via WiFi for iOS and via Bluetooth for Android): see Hardware | Carista OBD2 - Vehicle Diagnostics and Customization
You can see what customizations are available for your particular car for free; if you want to change any of the values, you have to buy the Pro Package, which currently costs $19.99 USD. It's a one-time in-app purchase that unlocks unlimited customizations and diagnostics on an unlimited number of cars.
Get it for iOS: https://itunes.apple.com/app/id954363569
Get it for Android: https://play.google.com/store/apps/d...ce%3Daudiworld
Check out this girl modding her C6
We are constantly adding new customizations (and we have a few new ones coming up for the Audi A6 C6 and C7), but here are some sample ones that were available on a particular customer's 2007 C6 through Carista (yours may vary based on year, model, country, options, etc.):
Doors / Windows / Remote:
Blink turn signals when locking doors
YES / NO
Blink turn signals when unlocking doors
YES / NO
Beep when alarm is armed
YES / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Enable settings for opening/closing windows and sunroof
YES / NO
Close windows via long-press on remote
YES / NO
Open windows via long-press on remote
YES / NO
Close sunroof via long-press on remote
YES / NO
Open sunroof via long-press on remote
YES / NO
Close windows by holding key in door lock
YES / NO
Close sunroof by holding key in door lock
YES / NO
Delay alarm activation
YES / NO
Instruments / Display / Dings:
Rear parking sensor beep volume
1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / MAX
Rear parking sensor beep tone
TYPE 1 / TYPE 2 / TYPE 3 / TYPE 4 / TYPE 5 / TYPE 6 / TYPE 7 / TYPE 8 / TYPE 9
Front parking sensor beep volume
Front parking sensor beep tone
Beep when parking sensor activated
YES / NO
Owner's manual in MMI
ENABLED / DISABLED
Lights:
Daytime running lights
ENABLED / ENABLED AND CONFIGURABLE IN MMI / DISABLED
Lighting configuration region
OTHER / NORTHERN EUROPEAN COUNTRIES / USA / CANADA
Lower headlights for traveling to RHD/LHD country
YES / NO
Flash brake lights in emergency stopping
YES / NO
Other:
Auto-enable rear wiper when front wipers on and reverse gear engaged
YES / NO
Carista's Avatar
Former Sponsor
And here's what's available on a 2014 C7:
Auto-lock doors when moving
YES / NO
Auto-unlock doors when key is taken out of ignition
YES / NO
Auto-lock trunk when moving
YES / NO
YES / NO
Unlock doors via smart key (door handle button)
YES / NO
Open/close windows and sunroof via long-press on remote
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
Sunroof action when opening via remote
SLIDE / TILT
Open/close only driver's window via remote or key
YES / NO
Open/close windows and sunroof via smart key
YES / NO
Close windows via smart key
YES / NO
Close sunroof via smart key
YES / NO
Open/close windows and sunroof by holding key in door lock
YES / NO
Open windows by holding key in door lock
YES / NO
Open sunroof by holding key in door lock
YES / NO
YES / NO
YES / NO
Close convertible roof via long-press on remote
YES / NO
Close convertible roof by holding key in door lock
YES / NO
Close convertible roof via smart key
YES / NO
Open convertible roof via long-press on remote
YES / NO
Open convertible roof by holding key in door lock
YES / NO
Blink turn signals when done closing windows via remote
YES / NO
Enable remote control when vehicle is running and in gear
YES / NO
Lights:
Allow configuring daytime running lights via dash display
YES / NO
Use front LED lights as daytime running lights
YES / NO
Use fog lights as daytime running lights
YES / NO
Use high beams as daytime running lights
YES / NO
Use tail lights as daytime running lights
YES / NO
Use side marker lights as daytime running lights
YES / NO
Use low beams as daytime running lights
YES / NO
Dim daytime running lights when ignition and parking lights are both on
YES / NO
Turn off daytime running lights ("wink") when turn signal is on
YES / NO
Coming-home lights
ENABLED / DISABLED
Leaving-home lights
ENABLED / DISABLED
Use fog lights as coming-home lights
YES / NO
Use low beams as coming-home lights
YES / NO
Coming-home lights duration
10 SECONDS / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
Ambient light threshold for leaving-home lights
0 / 1 / 2 / 3 / 4 / 5 / 6 / 7
Turn off front fog lights when high beams are on
YES / NO
Turn off rear fog lights when high beams are on
YES / NO
YES / NO
Flash hazard lights in emergency stopping
YES / NO
Turn on side marker lights with headlights (US models only)
YES / NO
"Euro" parking lights when ignition off, turn signal on
YES / NO
Other:
Lower passenger-side mirror when in reverse gear (may need memory seats)
YES / NO
Remember position when lowering passenger-side mirror in reverse gear
YES / NO
YES / NO
Carista
B8 Models
01-25-2016 07:47 PM
Carista
07-07-2015 11:13 AM
kiberon
B7 Models
02-03-2009 03:36 AM
Kitoone
03-20-2008 09:06 AM
DDonG
01-09-2005 04:18 AM
Quick Reply: C6 & C7 diagnostics and coding via a smartphone app: Carista OBD2
