Sponsored by:
Sponsored by:
Caliper bolt cap stuck, '99n
Old 05-10-2008, 01:19 PM
tomz322's Avatar
Default Caliper bolt cap stuck, '99n
I am new at replacing front rotors and pads. I used a pliers to tug on the caliper bolt rubber cap and it would not disengage. I also tried to pry one end with a screw driver and tug at the same time with no success. I am afraid that if I apply too much force the cap will tear.
Is there a certain technique to remove the rubber caliper bolt cap? Any thoughts?
Old 05-11-2008, 10:54 PM
Cmoney's Avatar
Default RE: Caliper bolt cap stuck, '99n
Hold on, you don't have to remove those rubber caps. They are just dust caps. There are two big bolts on the back of the caliper that hold it on. I think they are 18 or 19mm. A breaker bar or a long handled wrench or ratchet will help out a lot. I have a 2000 2.7. I'm not sure if your car is the same, but I don't think you have to remove those rubber caps. Good Luck.
Old 05-14-2008, 01:01 AM
a6hcw's Avatar
You need to get the Audi CD manual from Bentleypublishing.com, whereyou will find the correct bolt torques, etc. for your brakes. Of couse you could try autozone.com, for free instructions or for paid online instructions.
Old 05-14-2008, 10:20 AM
marko_tomas13's Avatar
No need to remove those rubber seals, only take the bolts behind them off and the caliper will come off.
Old 05-14-2008, 12:35 PM
NH_USA's Avatar
ORIGINAL: a6hcw
I really like this smiley........ [sm=icon_rtfm.gif]
bshusted
03-14-2012 01:27 PM
kevin1533
12-30-2009 05:33 PM
aloo
11-08-2008 04:40 PM
fibersnet
08-03-2007 11:50 PM
wood_e
08-08-2006 06:03 PM
Quick Reply: Caliper bolt cap stuck, '99n
