Sponsored by:
Sponsored by:
Cam Adjuster Replacement (4.2)
Old 03-13-2009, 02:52 PM
Khardysius's Avatar
Default Cam Adjuster Replacement (4.2)
Has anyone had to replace their cam adjusters?
The arm on the mechanical side of one of the diaphragms is broken and I need to replace it. Sadly, they don't replace just that 3.5inch long piece of plastic. Instead you have to order the whole cam adjuster kit which is like $400. So, a fix that could cost $3 in plastic is going to cost $400?
I suppose I'll be looking for some wrecked 4.2s or just fix the one I have with some crazy glue and a metal brace/duct tape/something!
This is sad.
Old 03-13-2009, 03:13 PM
nemohm's Avatar
Based on ones skills and determination some parts could be manufactured at home =>what is your filing dexterity? With aluminum?
Patience (Luke)?
Old 03-13-2009, 03:38 PM
Khardysius's Avatar
Honestly, I've been thinking about this. My quick fix idea is a combination of crazy glue and safety wire.
As for the aluminum, I'm sure I could do it. Where can I get a small piece of solid aluminum? I'm sure I can find/buy the necessary file.
Old 03-13-2009, 04:28 PM
nemohm's Avatar
Scrap yards - aircraft grade aluminum is you best bet...
Old 03-13-2009, 09:08 PM
auditech79's Avatar
That plastic piece on the tensioner is gonna have 50+lbs of pressure pulled down on it by the chain, so whatever you use make sure it is uber strong.
Old 03-13-2009, 11:33 PM
Khardysius's Avatar
Roger. I forgot I made this thread as well. Thanks auditech!
Amazing that little piece of plastic is capable of handling that amount of force. I'm not surprised it is broken now.
Palmer_AUDI
S4
02-21-2014 09:28 PM
mr peepers
03-01-2011 03:48 PM
gwos25
11-10-2009 01:08 PM
rib123
09-22-2005 04:34 AM
Quick Reply: Cam Adjuster Replacement (4.2)
