camshaft position timing belt over advance, (bank 1),
How do we fix the engine light camshaft position timing belt over advance, (bank 1), I had a mechanic who messed up my car by taking everything out in the front jkust to find an oil leak problem. Could someone have an idea
If he didn't even touch the timing belt, this isn't a good sign. I wouldn't drive it for fear that it could further jumping timing and destroy the engine. Well, not destroy it, but badly damage it.
From what I understand, if you're off by a tooth on one of the cams, the car will throw a CEL alerting you of the issue.
You may want to get in contact with the guy who last touched your car and ask him EXACTLY what he did to find this "oil leak" you speak of.
Thanks
since you need to reset the belt, you should replace it while you are at it.
even if you just replace the belt the belt is cheap.
You need an audi experienced mechanic to do it check around for a good one.
make sure he has the tools to do it. I only do my own and won't let anyone including the dealer near my cars ever again.
Thanks
Thanks
