Sponsored by:
Sponsored by:
Check your oil pan
Old 11-25-2012, 02:15 PM
02AudiA63L_65's Avatar
Default Check your oil pan
Here's what I discovered after removing the oil pan with 111,500 miles on an used engine...
Old 11-26-2012, 08:59 PM
PhilipM's Avatar
Does your oil temp gauge work?
Mine stop working, just wondering if that might be why.
I have 145,000 probably looks just like that lol...
My next oil change Ill take the pan off clean it and the Oil Level/temp Sensor...
before I buy one see if I can get it will work again..
Old 11-27-2012, 06:54 PM
Default Oil temp gauge works
I had to replace the original engine. Purchased the used engine online. Oil temp works. Water temp gauge is about half way. Use a can of oven cleaner on your oil pan (just like new) and used high temp RTV on the oil pan. I'm using Mobil synthetic 5W-30 (6.8 qts) and Mobil oil filter.
Old 11-28-2012, 09:44 PM
budhani786's Avatar
Is there anything im suppose to be looking at like a broken metal or something? Or are you talking about the sludge?
Old 11-30-2012, 10:52 PM
Just the sludge and heavy carbon deposits. I'll probably give the engine a good flush or two on the next oil change...
blackGM
07-25-2014 12:51 PM
joeynach
08-27-2011 06:57 PM
parlayin
02-10-2010 12:33 PM
mys4.org
10-16-2008 03:19 PM
Toff_the_Toffee
11-15-2005 10:15 AM
Quick Reply: Check your oil pan
