Sponsored by:
Sponsored by:
Got a poppin goin on.
Old 11-10-2009, 08:36 PM
jaceefis's Avatar
Default Got a poppin goin on.
A6 2.8 started popping and I think it maybe the vacumm system.Back firing through the exhaste comes on even more when the A/C is on. I have changed out some of the vacumm lines. Can a purge valve be cleaned and reused. Just was wondering.
Old 11-10-2009, 11:26 PM
Jackmup's Avatar
Timing
Try pulling codes and checking the cam position sensors and timing belt.
See if you have a P0300-6 the last number is the cyl maybe you have a messed up coil or ICU.
Old 11-11-2009, 10:53 PM
jaceefis's Avatar
Default Still at it
Well it's not the coil pack, also cleaned the purge valve and replaced all the vacumm lines. I will keep lookin or it's off to a good shop.
Old 11-12-2009, 12:31 AM
auditech79's Avatar
If its popping out the exhaust its not "backfiring" Its got more of a hicupp, too much or not enough fuel. DO you have a vag com? What does the long term fuel trim say in data block 32?
Old 11-12-2009, 05:40 PM
jaceefis's Avatar
Default Still not rtght
Don't have a Vagcom yet (so if there is anyone around Houston that has one there's a cold beer in it fir them). I did stop at Auto Zone and the P0301 code came up. Missfire on #1 cyl. Going home to read the spark plug to see just how they look. Check out the plug wire and all this. More later.Thanks for the help...
incrementalg
01-16-2010 08:43 PM
sakuraba
04-02-2008 11:42 PM
Notahondaowner
03-15-2008 03:30 PM
xav6ier
03-13-2007 08:31 PM
new2me
10-30-2006 06:56 PM
Quick Reply: Got a poppin goin on.
