Coolant leak, Info needed please
Hello all,
I have a 99' A6 2.8 Q, Auto and I have a coolant leak some where and it is driving me nuts, I have tried tracing this leak with no luck. Would anybody be willing to email me a copy or photo of the cooling system diagram, hoses, ect from a service manual? It would really help me out. Thanks in advance...
Jason
my email is roundelm3@msn.com
Jason
Waterpump --- waterpump -- waterpump -- it hides behind the front cover and the leakage dries before it gets to where it shows. You'll find red residu along the front of the motor. Other wise it might be the plastic tank.
A diagram won't help -- just use your eyes and follow the hoses etc.
Thanks for the replys, water pump was a thought but it seems that it is comming from somwhere in the back, there is a 3/8" hose that runs off the top rad hose, it connects to the resivor (with a T) and runs behind the motor to a round "something" (aux pump???) and it sounds like it is comming from there... That is why i was looking for a diagram to see what these parts are and the routing of the lines so I have an idea what I am looking at. I had the timing belt, water pump, thermostat and all that changed about 15k miles ago.
Thanks
Thanks
most likely your aux water pump under the intake manifold.
esppecially if you see the coolant leaking towards the back.
that and a cracked expansion tank are the two most common sources of a coolant leak IMO.
jen02
09-10-2013 10:29 PM
Cioffie
05-19-2013 10:24 PM
