Coolant Temp Low After Thermostat Change
I had my thermostat and water pump changed along with my timing belt this week. After the car heats up, the coolant temperature drops just above the 'cold' end of the gauge and stays there. It seems like an intermittent problem, as I've noticed on a few short trips that the gauge shows the temp right in the middle where it should be. Any ideas what this could be? Seems like an odd coincidence that the temperature sensor would happen to go at the same time the thermostat was changed.
edit: even at the cold end the gauge, the heater is still cranking out heat.
99% sure you have a temp sensor problem...
odd coinsidence...? Yes, but i've seen even worse with these cars
If the gauge jumps from normal to cold very quickly, or vice verse, then it probably is your coolant temperature sensor. You can get one pretty cheap, and replacement is pretty straight forward which can be done in less than 30 minutes.
It doesn't jump around quickly, but rather very gradually. I drove 400 miles today to Michigan and back, and I noticed when I first headed out, it heated up slowly to the middle of the gauge. After about 10 minutes, it gradually started to fall to the cold end of the gauge, and stayed there indefintely. It repeated this behavior on my way home. This is why it seems normal on short trips. Still the CTS?
Well I called back and he said there are 2 sensors, one measuring coolant going into the engine and one leaving the engine. They replaced the sensor on the coolant leaving the engine. Fortunately, they didn't charge me anything.
